Cant get on with Gibsons as the overal body shape/neck feels too substantial. I switch between a couple of CS Fenders and PRS (w/t and w/f) and everything is gravy.
I just can't get used to the longer scale length of a fender. Makes everything feel harder to play and I dont subscribe to the whole "I like a bit of fight in my guitar" bollocks.
I used to struggle a lot - to the point that I sold my first Les Paul because it felt like a ukulele!
Now I don't even notice it, as others have said - play both a lot, and practice changing, so play a couple on a strat and then switch to a Gibson etc.
Very quickly you'll not notice any difference
I do have dedicated straps for each guitar (albeit on detachable locks) and find having the correct length/playing position is important. Live I swap guitars on average every 4 numbers so the struggle is real.
Solution 1 - Les Paul, ES335, Fender Cyclone
Solution 2 - Tele Deluxe, Starcaster, Strat
My main issue is that while I can play just about any style on a Strat, I struggle to get clean or touch-of-breakup rhythm sounds on a Gibson that I like and will cut through in a live mix. I know it can be done, I hear other guys doing it, but I can't get happy with it myself.
1. Lowering the p/up heights
2. If your amp has both Hi & Lo input impedance options, plugging into the Lo input
3. Rolling off the guitar volume a little to help clean your tone.
4. Using a boutique pedal to 'pseudo' coil-tap your guitar. I have a Quasi Tap pedal that does this very well.
My current frustration is I'm playing in a retro band where a Gibson semi really looks the part better than a Suhr or DGT but doesn't sound the as good to my ears.
If I neglect the long scale ones for many months I might struggle going from the fat end to the dusty end unsighted for a few minutes.
Biggest upset was getting the Kobain Jag. I was at sea on that without watching the fretboard!!
