Removing an oil finish
Is acetone the best stuff for a job like this?
    Sanding is better.  If you are going to stain or refinish, you want to make sure you are back down to wood.  It doesn't need a lot and nothing too rough.  (Start with 120grit or even 180 and then go finer from there)
