Could need a tweak of a truss rod given where the buzz is but as it seems to be just one string it might be worth adjusting the action slightly first.
its annoying as this is actually the first guitar I've owned that I've had 'set up'.
otherwise comments as per above
I straightened the neck a bit and raised the action a hair to compensate and it fixed it.
Failing that, change you strings first, I have found buzzes that develop with a set of strings that go away by simply changing the strings. Alternatively you may have a high fret just ahead of where the buzz is and pushing the action up a little until you get that checked out and levelled should get rid of it.
