I personally would Rewire the cab to stereo, add a jack socket and run each head as a 1x12
giving the option of two amps at once from a simple A/B/Y Switcher.
Bright onion could knock you one up for buttons comparatively speaking.
So if I got this done, when only 1 amp is selected will the sound still come from both speakers, or would it only come from one?
Afaik you can't connect two output transformers to one load as you would end up back feeding into the the unused transformer.
Bad juju.
The headbone works by effectively having a loop in which your amps input and output sit, shutting off both at the same time, I think.
@ICBM
@ecc83
over to you gents.
I think Ampete do something for two heads and two cabs in any combination but, again, probably quite pricey.
The alternative would be to use a normal switcher but you MUST make sure both amps are in standby when you switch and the non-active amp MUST remain in standby when not connected to the cab. Remember though, accidental mistakes do happen.
Oh well, back to the drawing board! Thanks for your input guys
neo cream backs in them
small and light
PM me if interested.
R.
Eqd Speaker Cranker clone
"So if I got this done, when only 1 amp is selected will the sound still come from both speakers, or would it only come from one?"
Electrically the sound will only come from one speaker. However, in 2x12 the undriven cone will act as a 'passive radiator' and will add something to the proceedings in terms of tone if not level but since the level drop is only 3dB (assuming two amps together deliver the same power each) I doubt it would be noticed in a band situation unless you are using radically different voicings from the two amps.
Dave.
No worries. It's here if you want it, and does exactly what you want.
R.
