If I was buying one agin I wouldn't worry about the plus.
The biggest issue for me with this amp though is the FX loop doesn't work properly.
it's strange they've put the plus in that huge box. I could only think of valve rattle or
bigger reverb tank.
Noticed that the pro plus has a boost type thing called expansion. The video I've seen that sounds pretty decent. I know the original version didn't have this feature. Can anyone comment on the expansion feature?
It bypasses the tone stack so you get a fixed tone with it that isn't able to be controlled except with a single knob.
It is a rather blunt instrument.
I virtually never used it- an OD pedal on the front end does far more imho.
I'm trying to go for the Robben Ford type of lead sound. I'm unsure whether I'd be better with one of the TRs that have more overdrive? The jet or sensor maybe? Any thoughts on this one guys?
The thing is I've just tried the pedal platform thing. Maybe I should amp distortion next..
Zendrive on the front will get you there.
I currently use a Zendrive on the front of a 12w Princeton style amp and it sounds awesome because I can wind it up.
I'm still sceptical of the pedal route I guess.
Do you have 6L6's or EL34's in your V40?
He made a few with EL34's.
I find I can get a decent RF tone with any clean amp and a bit of EQ tweaking though.
I set the amp up with bass relatively low, maybe 2-4 (it stops it getting flubby), mids about 7, treble anywhere from 5-7.
Zendrive is set with gain up full, tone at 2 o'clock, voice up full and level about 5.
I control the gain from the guitar.
Take it you are setting the gain on the amp very low?
I think the key with a D type tone is to keep the mids high and the bass relatively low.
