Needs a clean up and service, I recently cleaned up a 68 where the filter caps had vomited all over the inside as they were well past it. + it will sound better too
Assuming you buy it, that is.
@breadfan I'll be sure to donate! Can you let me know how to?
I want it, lots.
Rob
This one looks pretty original to me, apart from the valve base and light as jacksparrow said.
In fact if you wanted to use it as a reliable working amp it needs to be made quite a bit *less* original, unfortunately!
Also don't send anything with one to Marshall, they'll replace it as a matter of course.
