The 50W models are the same circuit whether they're vertical or horizontal input - it's only the 100s which changed.
It's interesting how myths like this take hold though!
There certainly is diode clipping in the JCM800 Split-Channel amps - although interestingly there are three different circuit revisions of these, the first one of which is very different to the second two (and corresponds to the vertical-input MV models in date), but because there's no obvious visible difference from the outside like the vertical/horizontal inputs, fewer people seem aware of it… but the difference is much more important, if you like those amps. The difference is both in the preamp circuit (which really is almost totally different, apart from the control layout) and the power supply filtering, which is the same as the difference between the vertical and horizontal-input 100W MV models.
The other ironic thing is that despite the bad reputation diode clipping has, one of Marshall's most rated amps, the Jubilee, uses it...
The flying leads make it easier to change out single components without lifting the board. Also if you wanted to try any mods the vertical input version may be easier to work on
This is the vertical input version
This is an example of the horizontal inputs versions
Schematics are all online if you want to check them out
