IEM's, no monitor, no amp
matt1973matt1973 Frets: 386
edited June 2017 in Live
Just had this situation imposed on me under the moniker of it being "the future". Good earbuds Shure 425s' and an ok Thomann headphone amp deliver a good monitor mix but the guitar feels pretty dead and the tone from my Helix (which I think is a great bit of kit btw) is pretty artificial sounding.
Anyone been been through this and lived to tell the tale? It's making me pretty darn miserable at the moment.
  • deloreandelorean Frets: 224
    edited June 2017
    I get that using IEMs and the only way round it that worked for me was to keep one earphone out so that I still get some of the sound from the backline.
    Tweaking the monitor mix eq didn't help me much,  nor did putting up an extra mic just for ambient sound.  I'm still not 100% happy but it beats the hell outta floor monitors.
    Good luck dude
  • I tried the very same thing with an Atomic Amplifire 12, I had it running direct to the board. I Loved the sound out front through the PA, but just couldn't get away with the sound of the guitar through the In Ear Monitors.
    I persevered for 3 months hoping I would get used to it, but in the end I realised I needed a guitar amp on stage. So I went back to using a clean valve amp with pedals.
    I still use the IEM's though, both for monitoring vocals and the rest of the band. I have to say the sound of my guitar through a mic'd valve amp through the IEM's is so much better. If for some reason I'm not digging it, I just pull one of the earphones out so I can here the live sound of the amp.
  • RolandRoland Frets: 8724
    The guitar can sound dead when there's no acoustic coupling with an amp and speaker. Also the IRs that provide cabinet emulation deliver the type of sound that you'd get in a recording, and not what you're used to when playing live. Have you tried changing IRs, and adding "small room" reverb to the IEM feed?
    And another thing ... Despite how good the 425s are their frequency response is not flat. https://www.innerfidelity.com/images/ShureSE425.pdf. You need a multi band graphic, or a parametric with multiple bands, to smooth out the hills and valleys.
  • maltingsaudiomaltingsaudio Frets: 3135
    Interesting question arises from this, what is more important what the audience hears or what you hear?
    www.maltingsaudio.co.uk
  • matt1973matt1973 Frets: 386
    Very interesting comments guys. The main problem is the coupling issue - I have zero stage volume. As such I'm having to use more gain and delay than I would like to compensate which isn't ideal. I'll take a look at the eq correction - I've noticed there is a marked difference in the buds vs FOH so that could be useful.
    There's no right answer to that. The needs of the two groups are different.
  • ESBlondeESBlonde Frets: 3592
    Some say the inspiration of the player translates to better performance. Of course we could all use a cheap squire into a behringer digital box and get the sound out front, but instead we waste cash on valves, pedals and custom shop guitars with fake wear on them. But the actual sound out front varies little.
  • ash96ash96 Frets: 61
    This is a big one. I used my Kemper a lot more lately and felt like it sounded 'fake' and a bit fizzy in my IEMs (I always use IEMS now, and love them), however, it does actually sound a hell of a lot like my Victory V30. But because I know its not an amp, or I dont have a speaker, I question the tone more.
    I think its just a case of 'getting used to it' with IEMs. It is weird and does maybe feel a bit sterile to start with, but now I wouldn't go back.
    Now it feels weird not being able to hear everything so clearly, without having to absolutely crank my amp or whatever. I'm using this mainly for functions gigs atm, 2-3 gigs a week.
  • RocknRollDaveRocknRollDave Frets: 6503
    Played a gig once where no backline was allowed, so had to use in-ears and amp sims on my cheap multi-FX unit.
    No terrible, but way off what a good gig would have sounded and felt like
  • Danny1969Danny1969 Frets: 10425
    I certainly don't have a problem getting a great mic'ed sound in my iem's ... I would have thought the helix would have a pretty good speaker sim and virtual mic settings .... maybe do some tweaking
    one of my friends uses a palmer speaker simulator for his iem's and swears by it
  • welshboyowelshboyo Frets: 1816
    I use 425's and a Helix and do some gigs with no backline whatsoever - it sounds fine to me - however, I do tend to play with one earbud in sometimes just to get some ambience (you can still hear some of the out-front.
    I find it fine - just to clarify that your headphone mix is from the PA?
    Yeah the mix is from the PA guitar sounds great through a wedge and out front but terrible in the earbuds. I'm using the Ownhammer Marshall 4x12 which has worked well in all other instances.
  • ICBMICBM Frets: 72446
    In that case I would ditch the IEMs and use the wedge.
    I hate playing guitar through headphones of any kind.
    I'd absolutely love to but the people who run the band don't want the musicians to use any backline or stage monitors. Just IEMs :/
    Is it an acoustic drum kit?
    Yup although it has a clear sonic Perspex shield
    Hmm..ok, that's weird!!
    I use a Sennheiser Wireless IEM kit and also have a cheapo LD systems one as a backup and both sound great.
    Sounds to me like either the headphone mixer is being supplied with a less than ideal signal or the headphone mixer itself ain't great.
    In that case I would suggest you say you're going to use a wedge monitor or they can find another guitarist :). Zero stage level clearly isn't the issue, since even with a perspex shield the kit will be very audible on stage. So there's no reason you can't have some onstage level, especially if it isn't facing out front where it might interfere with the mix.
    If you're not enjoying it as it stands, that's what I would do anyway…
    This is something that really puzzles me about volume nazis soundmen in any set-up where there is an acoustic kit.
