Hi all, hoping somebody with knowledge of the Deco pedal can answer this, would be much appreciated
I understand that the pedal can operate with stereo inputs if you change something inside, which sounds good. But how does the echo element of it work then? Because I'd assume that with a mono input, the dry signal would probably go to one stereo output, and the delayed signal on the other virtual deck would go to the other stereo output.
But if the Input is already stereo, how is that routed? Is it merged to mono then bounced to stereo as per a normal mono input?
Thinking of it as an effect either after two separate guitar preamps at the same time, to get some retro sounding tape effect and/or slapback/doubletracking, or as a send effect on a mixer just as a tape effect
Thanks
That sounds complicated but is more straightforward than it sounds hands on. Get one they are brilliant! The only fault with it is that stereo input needs selected internally - this is a pain as if it is selected you have to always use stereo output as it won't sum to mono if you only connect the left output.
I'll say it again - get one, my favourite guitar related purchase for a long time, and I got a CS Jazzmaster the same week!
soundcloud.com/thecolourbox-1
