Due to an intermittent fault on my neck pickup I decided to completely rewire my PRS SE singlecut. Nothing complicated just two humbuckers, volume and tone with a push/pull on the tone pot to split the bridge pickup.
Everything works but I've now got a lot of noise and the only thing that reduces it is touching the plate around the jack socket. I'm assuming it's a grounding issue but I can't see that there are any problems. Everything that should be grounded has been. I've even double checked that the ground wire to the bridge is okay by running a wire from the front of the bridge to the back of the volume pot and I've checked that it's the guitar not the amp.
It may not be related but the usable range on my volume pot has decreased as well. It use to be fairly smooth across the range but below 6 and it's almost off now.
I'm at a bit of a loss here. I can solder well enough but I can only follow diagrams - I've no idea what I'm actually doing.
I'll have a look at the jack. I didn't unsolder the jack end of things be it could be that I've mixed up the live and ground leads. I'll report back...
All noise gone. The pot's still playing up but I'm not a huge volume knob tweaker so it's not a huge problem and can be sorted at a later date (probably when I get 'round to swapping out the irongears for some Guitar Weasel's offerings).
