marshall valvestate head with hum
nickpnickp Frets: 183
what are your thoughts on this?  aviod or go with it.  use: my backup amp but my son is also now going to use it and he do like his metal.
http://www.ebay.co.uk/itm/191066276890?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
just slightly concerned about the hum.
cheers
Nick
  • bertiebertie Frets: 13569
    I had a VS100r combo years back, and it certainly didnt noticibly hum
    Was bloody brilliant at picking up radio signals tho.
  • ICBMICBM Frets: 72339
    I would look for a good one... which you'll get for not a lot more than that.
    That one has at least two faults as well as being badly re-covered.
  • nickpnickp Frets: 183
    @icbm
    ok boss!  I'm doing what I been told and ignoring it
    cheers
    very good @bertie :)
  • ecc83ecc83 Frets: 1633
    Is that the amp that has a wee fan on the power chip that clogs up with ***t and then destroys the IC?
    Dave.
    edited February 2014
    No, that's the larger models in the MG-DFX series (especially the MG100DFX) and the AVT series (AVT50 and above). Just avoid those entirely!
    The earlier Valvestates (8*** series and VS series) and even the first MG series are much better-designed and more reliable, although they are getting old now and can have a few problems - reverb, failing ICs, filter caps, unsoldered power resistors, broken pots etc. They're so cheap and fairly common that it isn't worth paying too much for one that has known work needed.
    The current MG series has gone back to the previous discrete-component power stage design and seems to be almost complete reliable so far - I haven't seen a single dead one and they've been out about five years now.
