Or you could modify the fuzz pedal with a miniature buffer kit in the bypass path, so you get either the fuzz or the buffer but not both - that way you only need one footswitch press to select it.
Oh that pedal mod sounds good! It's a fulltone 69, can it be done to that?
I have considered just putting it after the fuzz but my pedals would go
tuner - wah - vibe - fuzz - od - delay
they're all true bypass so that's why I was thinking I'd like a buffer.
So the buffer would be after 4 pedals? I guess I could move the tuner to after the buffer!
Thanks again, appreciate the wisdom.
http://www.brightonion.co.uk/products/072-Buffer-Pedal-with-True-Bypass.html
That should work fine - the biggest cause of tone suck in an all-true-bypass setup is actually the long cable to the amp, not the short patch cables between the pedals, so even having the buffer right at the end is enough to fix it unless you've got a huge board with loads of patch cables. The usual accepted 'cutoff' where you start to hear a difference is about 5-6 pedals, so after four should be OK.
