If you want to run it from an isolated-outlet supply as many modern ones are, you just need to bypass these two components inside the pedal - you can often do it with a blob of solder, or with a small piece of wire if it won't reach. You do not need to remove the components - in fact in my opinion you shouldn't, it's more work and prevents it easily being put back to stock if it ever matters to anyone.
An unmodified one will also run perfectly from an isolated 12V supply, since that's really all the ACA is.
Why did Boss bother with it in the first place? It doesn't seem like the world's best design...
So they essentially put a basic regulator in the pedal, and made their own power supply sort of 'unregulated' as well. That seems to be a bit backwards, I know!
