FS Diamond Counterpoint Delay
Diamond Counter Point Delay
This is an amazing versatile delay. There is a lot of info on this pedal on there website. I would have a look and listen to some videos on youtube. It makes your playing more unique and can get the creative juices going.
Comes with box and instructions
https://i.imgur.com/64aF8ZM.jpg£170 delivered with box and instructions
this pedal Is inspiring and unique
https://www.gurusamps.com/en/1959-doubledeckerValve
This is basically brand new. Its such an amazing pedal. Very amp like. It has a clean channel, 2 marshall channels and a boost. The boost can be used on its own, or with either of the two channels to boost them. It has an effects loop. So you can run this into the front of the amp and run your delays and reverb into the loop.
You can also use a guitar jack to plug from the DI into a desk or a computer for recording. SO amazing! You could use this as a back up for your main amp, use it as your main amp, recording etc
The only reason i'm selling is i have sold a lot of gear and ended up with a marshall style amp so i don't really need this now.
https://i.imgur.com/FTF8UTi.jpg
https://i.imgur.com/4bNECrJ.jpg
https://i.imgur.com/KWFMPdf.jpg
