Not that I'm going to dump the pedals (again) but I'm tired of a board that seems to malfunction just for gigs .
I'm not a deep editor type so much prefer knobs to twiddle and things that are easy to set up and gig with
What i'd like- in front of the amp - compression, wah and boost pre amp (boost mostly to get strat volume similar to LP)
in the loop - delays and modulations, and maybe a volume boost (or I'll stick a eq pedal in the line to get same result)
half decent drives just in case we end up at a festival using their backline .
Have a look at a Helix (possibly the LT) - yes it does a lot more than that but it's incredibly straightforward to set up - the interface is very flat, no menus and submenus - does all the stuff you want and sounds grand.
Plus you get the USB interface stuff, excellent real-time control, editing and tweaking by foot...
You could even consider a Line 6 M13 but it has no expression pedal, again in 4cm;
..and lesser still a M9 but again no expression pedal or 4CM setup option (although used to great effect by Dann Huff recently)
No, they don't come with them, but with a very simple modification you can use the M-Audio EX-P pedal, which will cost you a princely £14.
certainly highlights the above issue.. but resolves it admirably...
Used it like that for years. You can split it anywhere along the 4 FX and add a couple of expression pedals for good measure
They are buttons second hand too
If you do then want to swap in modelled amps, I guess you have to balance the volume using the master volume in the parameters of the amp - which is a bit fiddly I guess. But doable.
I wonder how many people have had the same thing result in perceived tone suck with the HD500 in 4CM. It's not obvious to me that you would have a separate volume setting stored for when the amp is bypassed. Useful, I guess. Plus I suppose it means that you can still use the volume control to control the modelled amp volume separately. Cool.
I'm enjoying playing with this unit again. Using it into a power amp and real cab means I don't have to worry about the quality of the internal modelled cabs and it sounds pretty good. I'm liking the PV Panama model today
