http://www.homebase.co.uk/en/homebaseuk/evo-stik-wood-adhesive---125ml-087931
superglue is perfect.
Don't hold the bottle over the guitar neck though, and use it sparingly
edit - I use toothpicks to add a drop of glue where I want it.
Instagram
Get a good superglue though, we use one with a spray on activator to set it.
Mind you, I got precisely nowhere with using a cocktail stick, so I dipped the inlay sticks (very slightly) into the nozzle of the glue tube...worked a treat.
Sadly, I have to get on with work now, so the filing and sanding will have to wait until this evening.
I'd originally worried that a single 60mm stick wouldn't be enough for one guitar, but it turns out it's probably good for two! If this works out OK, I may well do the other Jaden Tele too.
The important bit is never to hold a bottle of superglue over a guitar if you can help it
Instagram
WHEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
