Hi there,
I've done a search on this but can only mainly find people who've sold their's. Why is this? If this is such a revolutionary tone savior then why are they getting sold? Is there a minimum amount of pedals you would need for it to have a noticeable effect?
My chain at the moment consists of 6 pedals, included are a Cornish buffer and audio kitchen small trees preamp, so the signal does get pimped already. But still, it never feels the same as going straight in.
Any thoughts? Also, the cable looks like my Cornish cable, is it the same?
Cheers!
Imaginative marketing hype.
From what I understand the GigRig one seems to work by having an audio transformer in the cable (and possibly some other gadgetry) so that to the amp, it behaves somewhat like a guitar pickup rather than like a buffered output.
So, good but not *that* good?
I'm actually genuinely curious about it - one thing I have discovered from experience is that old transformer-balanced DI boxes sound better for guitar (and bass) than the 'better' electronically balanced type (similar to a buffer).
Ah! I see it is an active device so, there is a lot of potential for it to be useful. Really speaking it would IMHO have been better being split, a buffer from the guitar, perhaps with some HF pre-emphasis? Then a 'receiver' post pedal chain to compensate for any losses.
But since the makers cannot know the source impedance of guitar or pedals nor, to a degree the input Z of the amplifier I am not surprised people love or hate them. That is not to say I think the cable is totally great, bit of BS there!
"I'm actually genuinely curious about it - one thing I have discovered from experience is that old transformer-balanced DI boxes sound better for guitar (and bass) than the 'better' electronically balanced type (similar to a buffer). "
'Better' IC or just more preferred? This is possibly another case of what is TECHNICALLY best does not translate to SOUNDING the best in a guitar scenario? Even the 'hottest' passive, traff based DI box will only present some 280k to the guitar. An active DI SHOULD present the 'magic meg' . It is sometimes said that the transformers impart 'colour' but I doubt it. Guitar signal levels are pretty low and are unlikely to drive such a transformer into distortion?
That said, some of the cheaper DIs use a VERY wee traff! Be interesting to see if there is an inverse correlation twixt DI box cost (hence traff quality) and subjective judgement of 'niceness'?
But like SO many things to do with guitars/amps etc, NOBODY is doing any serious work AFAIK.
Dave.
For DI'ing an un-preamped instrument, or anything acoustic (preamped or not) where you want it squeaky clean, active all the way.
It is very subjective, certainly. I would also be interested to see if there's any correlation - I wouldn't be at all surprised if the 'worse' they are technically, the 'better' they sound for guitar.
It does indeed have an audio transformer, along with a balanced cable, certainly not pseudo-science
I've had it for a fair while, the problem I have is that if I use it on one side of the rig and not the other I end up with a mismatch of signal that annoys me. So it is great, but I have moved to a totally over the top and different setup that switches amp heads and outputs buffered guitar signal to four separate heads, and cabs (AMPETE 4X4|) sort of like a pedal looper for amps.
