Solid state Combo amp?
BloodEagleBloodEagle Frets: 5320
edited July 2017 in Amps
Does anyone have any recommendations for a good solid state Combo which does good cleans, takes pedals well, sounds 'big' and preferably has 1 or 2 12" speakers. I'm not bothered about built in effects but I'm not bothered if they are their either. I not bothered about it having a gain or od channel. Current contenders include a Blackstar id60 or a Roland jc40. Any other ideas?
«13
  • ICBMICBM Frets: 72325
    Peavey Bandit or Special
    Orange Crush 60 or 120
    Fender Champion 100
  • vasselmeyervasselmeyer Frets: 3672
    If you're looking at combos then the Peavey Bandit or  Award-Session Blues Baby.
    If you want a very small but powerful head then the Quliter or DV Mark heads are less than 5kg and will work with pretty much any cab.
  • BRISTOL86BRISTOL86 Frets: 1920
    To jump on the bandwagon (without trying to derail the thread) I'm also looking for a SS amp which will give great cleans at home use volumes.
    Had a recommendation for a Blues Cube Hot - any experience here of that amp? Thanks.
  • BloodEagleBloodEagle Frets: 5320
    Some very helpful info here, thankyou gents
    The Blackstar and the Roland seem weirdly at odds with each other. The DV Mark Jazz combos might be a viable alternative to the Roland and there's a new 2x12.
    I was using a Bandit last night. I'm not sure they sound 'big' and they take a bit of dialling in ( just too many knobs and switches) but when you have it's possible to set up a great base tone that's very happy with pedals.
  • darthed1981darthed1981 Frets: 11754
    Boss Katana! :)  Great all-rounder, not pure "solid state" but not really a "modelling" amp - well worth an audition I love mine
  • simonksimonk Frets: 1467
    Quilter head plus a lightweight cab. Herein happiness lies.
  • midlifecrisismidlifecrisis Frets: 2343
     i s. econd the boss katana. i wasnt bothered about having onboard effects but they actually work quite well.
  • 57Deluxe57Deluxe Frets: 7339
    Session BluesBaby...
    <Vintage BOSS Upgrades>
  • JayGeeJayGee Frets: 1260
    I third the Katana. Genuinely good sounding amp for a stupidly low price. I've owned mine for about a month, done a couple of gigs and several rehearsals and I'm still looking for the catch...
    I like the Tech 21 Trademark combos but then I've never tried a Katana.
    I use a Fender Champion 110 for a lot of gigs, tiny amp that sounds great. Needs mic;ing for bigger gigs mind
  • mellowsunmellowsun Frets: 2422
    The JC40 has a decent sound stage with its 2x10 speakers although lacks a bit on the bottom end.
    It takes pedals really well and it has a stereo fx loop which is pretty rare (ping pong delay sounds brilliant).
    It's pricier than the alternatives but it's built like a tank
  • rlwrlw Frets: 4696
    Vox AV60 should be worth a try, or the AV30 with a 10" speaker.
  • LegionreturnsLegionreturns Frets: 7965
    If you're coming to the jam you're welcome to try out my Katana100 1x12. I have to footswitch for it and additional pedals. Huge sound for the price!
  • VoxmanVoxman Frets: 4723
    edited July 2017
    Marshall Valvestate - I have the 8080 1x12 '80v' - the most popular Marshall amp ever made.  Proper 2 channel, footswitchable amp with a master volume, a proper spring reverb, clean/crunch and OD1/OD2 channel, contour control (effectively a versatile EQ circuit) series fx loop with loop level switch, line-out, Celestion G12T75 speaker (this may vary).  Cracking little amp (also comes as a 2x12), good cleans, nice Marshall crunch, and great with MFX or conventional pedals.
  • LooseMooseLooseMoose Frets: 908
    Katanas are good amps but if you wanted something simpler and beefier then the Orange CR120 is where it's at in my opinion!
    It's basically a mid shift/scoop control - at Marshall they called it the "old guy/young guy knob" apparently :).
    The 'Marshall Gold Back' Eminence is more common, I think - but the G12T-75 sounds better.
    I've always thought that if they'd made them with a ply cabinet, standard Marshall styling and slightly better build quality - basically a circuit update of the JCM800 solid state series - they would have made a genuinely great amp. It would have been more expensive and probably sold less well though...
  • ellwoodellwood Frets: 1113
    Tech 21 Trademark 60, every time. I have one in Hinckley if you want to try one
  • manimani Frets: 10
    A great amp - excellent cleans
