Whether it will reduce the bass enough to keep the neighbours happy, I'm not sure. I know this sounds like I'm insulting your intelligence , but have you tried turning the bass down on the amp? If it's not already at zero then turning it down will probably make more difference than the speaker.
If you've tried that already and it's not enough, you could also try a 10" speaker instead of a 12" in the same way, which will reduce bass and volume further.
On one of the reviews on Amazon I just noticed a 'stopped the neighbours downstairs' complaining comment.
Nil Satis Nisi Optimum
A reducer sounds doable. I had a quick look and the amp and cabinet appear to be straightforward to disassemble. Lots of screws, nuts and bolts. Once the current speaker mount was removed it could be used as a template for a new mount with 12/10 inch port.
Hmmm ... I think the next step is to borrow a couple of friends 1x12 cabinet and Princeton and try running it through them.
What I am looking for is the same tone I have but just hitting my ears rather than spreading out so much.
Thank you for the tips
Decoupling it from the floor will significantly reduce the bass going through to you neighbours.
In that case, if you're going to try a smaller speaker then a 10" will probably sound more like the 15" than a 12". I can't remember the exact physics behind it, but there is a reason… it's also why bass amps traditionally more often use 10s and 15s than 12s.
From that point of view a 10 inch sounds like a good match.
Thanks to everyone else. I actually have it on two layers of Auralex foam already but like the idea of a tighter low end.
https://i.imgur.com/SNkHSps.jpg
Regal II with 15 inch Eminence.
https://i.imgur.com/kjp1G7G.jpg
This is what the back of a 15 inch Eminence looks like
https://i.imgur.com/T9O3jWf.jpg
I really hope this works out
https://i.imgur.com/0DIQSP4.jpg
After some discussion and advice @RiftAmps sent me this lovely new 12 inch baffle ready to take my new WGS G12C.
https://i.imgur.com/1lj02oj.jpg
Success!
Victoria with new 12 inch installed
The last picture is a joke at my expense as it is the same picture of the amp. It may seem like quite a bit of hassle for 3 inches but the difference is already evident. I can turn the bass control up to 5 or even 6 without taking the plaster off the ceiling in the room below. I don't want to overstate the improvement yet as I have only tried the new speaker for an hour but I think the tone is better. There seems to be more definition across the tonal range. I would describe the 15 inch as nearly like a bass with guitar on top whereas the 12 inch is all guitar. I know what I mean and I can't imagine a better amp for me (until the next time @RiftAmps posts, or there is a ToneKing/Carr/Lazy J in the classifieds).
