At the moment I am using a MarkBass MiniMark. A great amp but its limitations are max volume. I like the 'sound' of a MarkBass rig but the cost of the items are prohibitive at the moment. As always! On an Irish 'items for sale' website the following kit is offered:
http://www.adverts.ie/bass-amps/gallien-krueger-bass-rig/6426652
Looks and reads impressive but what is the opinions of those here who are in the know about these things. In August I plan to buy a MIM Fender Precision bass. Would that rig and the P bass give me the same comfy country thump that the MarkBass gives? My playing style is mainly roots, ascending and descending runs etc., no slap or bass solos. Think Don Williams, The Eagles, Smokie etc.
Thanks.
Have you considered the size and especially the weight though? I suspect there is a reason the seller is looking to trade for a MarkBass .
If I were you I would hold out for a MarkBass Little Mark head and a 1x12", 1x15" or 2x10" cab. A friend of mine gigs in that type of band/style, he uses the 1x12" for smaller gigs and adds the 1x15" for bigger ones.
If I recall correctly, the Fender MIM Precision Bass mentioned in the opening post was to mark a landmark birthday. Do you really want to be lugging gear the size of that fight-cased G-K rig? Do you have a vehicle that could accommodate it?
According to their website, the MiniMark combos deliver 150w RMS through the onboard loudspeaker(s), increasing to 250w RMS when an extension cabinet is added. Would that be loud enough?
Nil Satis Nisi Optimum
Even if you don't want to risk running the amp full up, simply using a larger and more efficient cab as well would probably give you a lot more volume - for this I would definitely go for a 15" cab.
The trick is to find one that's small and light enough... they tend not to be if also cheap.
The head is an Ampeg B500 DR -- good condition because it lives in a rack/ case.
The cab is an Ampeg B410 HLF -- road worn and gigged without being tatty. Central tweeter disconnected a while back without apparent effect, (cos the tweeter died) but simple to replace although it didn't seem to do anything.
It's a gig ready rig and can hold its own on any stage.
There's also a 1x15 in a home made cab which adds awesomeness to the sound -- but not to the portability!
I'm pretty sure he'd take £500 the lot -- literally just wants to clear it before he goes.
I cannot help wondering whether putting your disposable funds towards an extension cab might bring greater improvement to your overall set-up than spending that same sum on your next bass guitar.
