Soldering iron issues...."S-E" Error code
Evening all,
In January i bought an ATTEN 938D solderin station....approx £60 or so.
Its served me very, very well....until this evening.
The tip does not heat up and the digital screen just says "S-E"
Is this a heating element failure?
Ive used it extensively since January....guess I'll have to invest in a Hakko which I've been meaning to do for ages.
thanks all
  • SteveRobinsonSteveRobinson Frets: 7028
    Make sure the iron hasn't become unplugged from the base unit
  • FunkfingersFunkfingers Frets: 14424
    Google is your friend.
    Apparently, "S-E" indicates (temperature) Sensor Error.
    Even assuming that the defective part(s) can be serviced or replaced, you will definitely need a second soldering iron or station in order to work on the first one.
  • wackojackowackojacko Frets: 59
    Hi yeah I saw that.
    I found the problem. One of the heating element wires had come undone from a bad looking solder joint on the circuit board.
    Ive fixed it for now somehow...but will need as you say a second soldering iron to fix it more permanently.
