Alternative to Allen key?
DefaultMDefaultM Frets: 7326
I need a 0.5mm Allen key for my graphtech string saver saddles to adjust the action, but I can't find one anywhere.
Does anyone know where I could get one, or another way to adjust the saddles?
  • m_cm_c Frets: 1240
    Small torx bits are far more common, and there's likely one that would fit well. I'd measure some up for you, but I'm currently on holiday. I'll be home on Sunday if you've not found a solution by then.
  • gavin_axecastergavin_axecaster Frets: 526
    edited July 2017 tFB Trader
    0.5mm? That's tiny. You sure it's not 0.50" which is about 1.27mm and a common size on US/US spec saddles.
  • mudslide73mudslide73 Frets: 3072
    +1 for Torx bits.
  • DefaultMDefaultM Frets: 7326
    I'm pretty sure it's 0.5mm because I've got a 1mm and that doesn't fit. All I could find was a 0.7mm in B&Q and that looked absolutely tiny, so yes it does seem like I need the smallest thing in the world.
  • professorbenprofessorben Frets: 5105
    edited July 2017
    I think the Trem tightness lug on my PRS is 0.5mm.
    Its bloody tiny, I had to buy a whole 24pc set to get it.
    Only a fiver off eBay tho.
  • SteveRobinsonSteveRobinson Frets: 7031
    It's probably 50 thou. (1/20")
    Metric ones are usually 1.5mm
    Probably Stewart McDonald would have something.
    http://shopgraphtech.com/product-377-2/
    This would seem to be the key for most Graphtech string saver saddles - .050" (50 thousands of an inch)
    I've got a full set of keys at home already and none of them fit, as in they're visibly too big. The smallest is a 1.0, and they increase by 0.5 up to probably 7?
    You have a full set of metric Allen keys. The screws are Imperial size.
    They're different sizes? I always see the different sets but just thought they were the same tools labelled in different ways.
    Yes. Using the wrong size is a sure-fire way to ruin your grub screws/truss rod adjuster etc...
  • maltingsaudiomaltingsaudio Frets: 3127
    I bought one of these https://www.amazon.co.uk/Mini-Pocket-Pen-Shaped-Screwdriver/dp/B005ZZ2PH6 and it seems to have bits you can ram into allen bolts which work, did my wilkinson trem a treat
    www.maltingsaudio.co.uk
  • AlnicoAlnico Frets: 4616
    I just bought a ball ended screwdriver style one to do my Strat with.
    I've got a spare L shaped one that came with the Strat if you'd like it, I can post it to you tomorrow?
    PM me your address if you want it.
    No problem.
    It is 0.05". - 1.27mm for a USA strat like mine so I would assume it's the same for those saddles you have.
  • FelineGuitarsFelineGuitars Frets: 11594
    Get the Cruz Tools multi-tool - it has the 0.05" as well as all the other useful guitar sizes too
    We keep it in stock if you need a supplier.
    Graphtech sizes are usually 0.05"  1.5mm and 1/16" - maybe 3/32 on a large item
  • 57Deluxe57Deluxe Frets: 7339
    Edgar Allen Poe...
    <Vintage BOSS Upgrades>
    No problem.
    Thanks very much for the offer but I ordered 2 from eBay yesterday.
    I've always looked at the cruztools and thought I had no need for it because I had the Allen keys separate. However, I keep losing them so i should probably invest.
    No problem at all.
    Glad you're sorted.
    Well they're here and they fit, so you learn something new every day!
