Please delete
d8md8m Frets: 2434
edited February 2014 in Making & Modding
  • TTonyTTony Frets: 27639
    Hmmmmm, a hinged neck.
    1.  Does the hinge protrude from the bottom edge of the neck?
    2.  Is the joint strong/accurate enough to support the tension of the strings, and accurate enough to ensure that the guitar doesn't need a re set-up every time that it's unhinged/rehinged?
    3.  Would you be developing it for your own use only (satisfying, if expensive), or aiming to make it commercially (ambitious and even more expensive)?
