Hi guys,
Borrowed my mate's G3 the other day to give it a bash, and wondered a few things that he didn't know the answer to:
1. He used it into the front of his amp, whereas I'm running it into my FX Loop of my Marshall JVM with 4x12 (100% wet FX Loop in series) Which setting should I choose from "Combo, Stack, Direct"?
2. I found that when I kicked my FX Loop on, there appeared to be a noticeable drop in volume. I've got my loop set to +4db, and I tried turning the Global volume to max on the G3, but there still seemed to be a volume drop. I was only using delay on the G3, so it wasn't an effect with a "volume" setting. Anything else I should be checking? I'm guessing this could be related to my first question?
Any pointers would be greatly welcomed
1, none, that'd be like putting a drive pedal in the loop* which is a no-no.
2, when I had a G3, there was a noticable volume difference between some settings.
*ICBM'll be along in a minute to tell me it's alright to put a G3 there..
My plan was to set up a signal path of all modulation as it would be permanently in my FX loop, which should hopefully remove the potential threat of accidentally selecting a dirt box!!
Will try changing the speaker emualtion to one of those two and see how it sounds. Really hoping it sounds decent.....already sold my M5 and need a replacement ASAP!
