Paint stripper question
So, I have a GSPBASSES thinline Strat body in Mahogany with a quilted maple top, that I finished in Green ink and Tru Oil, I've never liked the finish, so I have stripped the Tru Oil with paint stripper which went very well, it needs the ink layer sanding off the quilted maple top and a general all over sanding, but the question is, how do I remove all the paint stripper residue so it does not affect the next finish? Stripper is water based, but I'm loathe to run it under a tap!......
Any suggestions guys?
Refinish will be stain then either Tru Oil or Wipe on Poly......
  • ICBMICBM Frets: 72821
    edited August 2017
    http://homewoodcraft.com/wp-content/uploads/2014/06/81IR10Z9OiL._SL1500_.jpg
    That will fix the quilt top at the same time.
    Sorry . If the stripper is water-based, wet kitchen roll should take it off without saturating the wood too much.
  • paulnb57paulnb57 Frets: 3087
    Wis or lol?
    Cheers!
    Once wiped off, why not go solid colour - primer, colour, and clear coat and you don't have to worry about sanding off that ink layer then!
    Solid colour over quilted maple? Get your coat!
    Quilted Maple on a Strat? You need your hat and brolly on the way out too ;)
    It gets worse @Bridgehouse ;, it's Quilted Maple over Mahogany with a hardtail bridge, two Humbuckers and a Birdseye Maple neck........Oh the shame, the shame....
    There may also be an f hole.....
    Just call it a Superstrat and you can get away with absolutely anything.
    Oh. Apart from that.
  • CorvusCorvus Frets: 2970
    The active ingredient will have fecked off in no time, so a damp wipe down should clean anything else off if it's waterbased. Will prob raise the grain which is a slight bonus anyway, so a light going over with a scraper will bring it up lovely & smooth, and do that bit extra cleaning as it goes too.
    That's good to know @Corvus ;
    Thanks!
  • DeadmanDeadman Frets: 3953
    Wash stripper off metal with water by all means but degrease it afterwards. To simply wipe it with a damp cloth on wood could lead to problems when you come to paint.
    I always degrease wood with a fast evaporating solvent after stripping. It ensures no residue gets left behind and gives you a clean substrate to work on.
