Hi all
Getting into practicing with a band again, hopefully gigging soon.
I have been (trying to) use my amp 'cranked' with little luck so far - the speaker that made it a perfect pedal platform, an Eminence Cannabis Rex is both too efficient and bassy to work well in this situation. The amp is an MJW JTM45 clone with 15watts of power.
I do however like the smooth top end of the C.Rex - can anyone recommend a 12 inch speaker with a tight, subdued bass, smooth top end and low efficiency? The C.Rex is 103db (!) so something around 97db might make it more 'crankable'.
I have had some success using a 1x10 in my VHT. It's an Eminence 105 - I like the bass response (I've always liked 10s) but the top end is too 'crunchy' and bright. It's not a smooth combination. A 2x10 is a possibility but I don't want to give up on a nice portable 1x12 just yet.
Cheers for your collective wisdom!!
Just checked and they've got bloody expensive.
https://m.thomann.de/gb/celestion_g12m_heritage_greenback_8_ohm.htm
If you can find the EVH Celestion driver it's exactly the same apparently but costs alot less. I got two second hand to try out in a 2 X 12 to risk with my 50w head.
PA Hire and Event Management
The harder you drive it (easy at its rating) the more its mid-voice character contributes to the sound (ime)
Maybe the 103db is optimistic or they measure differently to Celestion.
It is, but it's also a little tighter at the bottom end and darker at the top, I think - I haven't directly A/B'd them with the same amp though. The same seems to be true for the G12H-75 Creamback vs. the G12H-30.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
