Please advise on a great distortion pedal...
MikkiMcMurdererMikkiMcMurderer Frets: 352
edited August 2017 in FX
I know these type of subjects have been discussed before but pls give me a bit of your experience of best distortion pedals particularly for humbucker guitars into big clean amps for playing hard rock 80s/90s style.
  • benmurray85benmurray85 Frets: 1396
    Whats your budget? I know its probably overkill but I recently got  Strymon Sunset and am using it into a Fender Hot Rod. I didnt expect it to do distortion well but it really does! If you're looking budget go for a RAT!
    How very rock and roll
  • I forgot to mention I need it to be the same footprint as an OCD type pedal so dual pedals are out of scope.
  • BabonesBabones Frets: 1206
    edited August 2017
    Boss DS-1. Maxon SD9, MXR Distortion +, RAT...
  • stickyfiddlestickyfiddle Frets: 27153
    Selah Feather Drive. Not sure if you can get them in the UK, by it's a great pedal
  • UnclePsychosisUnclePsychosis Frets: 12930
    edited August 2017
    Depends on the amp but Ds-1 / Ds-2 / RAT / Dist+ all tend to do it for me.
  • Thank you all so far! Please keep the suggestions coming! The amp is an Orange OR100 into a Zilla 2x12 with Creamback. BTW.
  • SassafrasSassafras Frets: 30301
    Apart from the Rat my other favourite is the Way Huge Fat Sandwich. It's a very nasty and aggressive distortion. If you want smooth distortion, look elsewhere.
  • PolarityManPolarityMan Frets: 7295
    sansamp gt-2
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    The best standalone modern drive is the Mesa throttle box, medium to high gain it's pretty hard to beat
  • kennedydream1980kennedydream1980 Frets: 1156
    edited August 2017
    Suhr Riot or Tone Freak Severe :-)
  • mike_lmike_l Frets: 5700
    I've not tried an Orange amp, but here's a few to look at.
    MXR Distortion 3
    MXR Custom Badass (there's a few to choose from)
    MXR GT-OD
    Boss SD-1 (easy to mod as well)
    Boss DS-1 (same again)
    I just got an AMT S-Drive and it's great, and amazingly quiet when boosted with a Tubescreamer.  It's their take on a Soldano, so probably would be what you're after.
    Amptweaker Tightrock is another one to consider.
    For the price, the AMT is great.
  • TC Dark Matter is a great pedal for a Marshally type dist, or as I use it as a dirty boost to tighten low end.
  • steersteer Frets: 1196
    Rat or Guvnor?
  • FezFez Frets: 528
    Mad Professor Little green Wonder or Sweet Honey Overdrive, they have some others as well. Also look at the Rothwell Hellbender or Switchblade.
    Don't touch that dial.
  • SD-1 to boost your Orange?
  • 57Deluxe57Deluxe Frets: 7344
    There is no great Distortion pedal. What will be great is finding one which works with your amp and sundries. Sometimes a Fuzz is better than a DS and often, DS works better than a Fuzz. Sometimes a Fuzz and a TS gives great DS. If your amp is SS then this latter option would be pref as you will have a much harder time finding a match...
    <Vintage BOSS Upgrades>
    Distortion pedals ie not overdrive....cheap n still great - mooer cruncher. Expensive n very brown sound - wampler pinnacle.
    Jackhammer and Guv'nor both great to for cheap as chips money....
  • GassageGassage Frets: 30935
    For your need- Wampler Euphoria. Still a great.
  • digitalscreamdigitalscream Frets: 26701
    Best distortion pedal I've ever encountered is the Bogner Ecstasy Red. It's got huge range (everything from light blues to crushing metal) should you want it, but its real strength lies in the middle ground - brilliant for 80-90s rock and metal. Immensely tweakable (the variac switch is a wonder) and the fact that the boost is a gain + volume boost means you can basically add two more channels to your single-channel clean amp.
    The only reason I'm selling mine is that I've got a Helix which does everything I need.
    <space for hire>
