Tiny tuner
hotpickupshotpickups Frets: 1822
can anyone recommend a tiny tuner as I have a very small footprint available on my board.   Doesn't have to be all singing and dancing one but accurate at least ;)
  • digitalscreamdigitalscream Frets: 26690
    How tiny is "tiny"? The Korg Pitchblack is pretty small and always reliable. I found the TC Polytune Mini to be quite noisy when it's engaged, so I've kind of ignored it since I got rid.
    <space for hire>
  • simonksimonk Frets: 1467
    Polytune mini, Pitchblack mini and the Mooer one are all OK. Polytune would be my choice.
  • JDEJDE Frets: 1092
    The Ibanez Big Mini is decent, small and sensibly priced
  • hotpickupshotpickups Frets: 1822
    Yes I'm leaning towards the polytune. Would you or someone mind measuring the width it takes up with the plugs in the sides please ?
    Doesn't that depend on which leads you are using and thus the size of the plugs?
    lol yes I was just about to edit my comment :) I use Evidence Audio SIS plugs
  • EricTheWearyEricTheWeary Frets: 16298
    The D'addario one looks tiny and bright ( if a bit more expensive than the competition).
  • GulliverGulliver Frets: 850
    8cm including plugs
    edited August 2017
    lol yes I was just about to edit my comment I use Evidence Audio SIS plugs
    8cm including plugs
    Bugger I don't have enough room on my board then
    EDIT: Actually if I move a few bits that polythene would just fir in with some creative wiring LOL. Thanks guys
  • VJIvesVJIves Frets: 466
    The Boss TU3s is pretty diddy.
    Unfortunately not diddy enough for my board :( Gonna have to be long and thin and will be viewed side ways
  • I'd go with the Polytune Mini, used to own one.
    Pitch black mini is 6mm narrower than the polytune!
    That's the one then as all mm are at a premium in this case. Plus it runs on lithium batteries which should last ages if ned be ;) But I will be powering it by a power supply :) Thanks guys.
  • SassafrasSassafras Frets: 30301
    Those EBS patch cables are about the thinnest I've seen. That'll shave a few mms off. I wouldn't get another Polytune pedal, mine's a bit temperamental and the screen lifted off.
  • RockerRocker Frets: 4987
    Does it have to be on your pedalboard?  Velcro one on top of your amp.  Get a decent tuner.  As the advert states 'you are either in tune or you are not'
    Nil Satis Nisi Optimum
    No it doesn't have to but just trying to avoid extra cables etc. Also I'm using a looper/switcher that when muted will turn on the tuner etc. I think the Korg would work and that's a reputable tuner :)
  • english_bobenglish_bob Frets: 5162
    Yeah, a sort of rumbling noise.
    All my pedals run off a daisy chain except my M5s, which are also noisy if not isolated. I wonder if using an isolated supply would fix the issue with the Polytune.
    edited August 2017
    Wow this is truely tiny. Perfect
    https://imgur.com/a/WE8kR
