Volume pedal advice please
BluesyDaveBluesyDave Frets: 411
I'm thinking about adding a volume pedal.  All my stomps go in to the front of the amp (no fx loop) and there is only 5 of them.  Guitar - tuner - EP booster - Prince of tone - Giga delay - Flint, is the order.  I have single coil and humbucker guitars.  So my question is, which would be the appropriate volume pedal?  I've seen high and low impedence but have no idea what this means.
No Darling....I've had that ages.
  • JDEJDE Frets: 1092
    Depends where in your chain you want it - low impedance pedals need to be used with a buffered signal of some sort, so in the middle or end of your chain, or if you have active pickups. High impedance can pretty much be used anywhere, although they do not work correctly with active pickups. If you have regular, passive pickups, I'd go for a Boss FV500H - built like a tank and minimum volume knob. Big, but a great pedal.
  • vizviz Frets: 10700
    edited August 2017
    I used to have a Little Alligator in the loop, but I found a boost was actually better, simpler, and smaller, so unless you need the sweeps, maybe consider something like a mini Keeley Katana Boost. I love mine.
  • stickyfiddlestickyfiddle Frets: 27113
    I'm a big fan of the Ernie Ball ones.
  • BluesyDaveBluesyDave Frets: 411
    I'm looking to use it for swells rather than boosting anything.  Great in combination with echo and verb......at least that's what I'm hoping.
    edited August 2017
    My personal favourite is the Dunlop DVP-1.  It's huge and makes a crybaby look small, and they do make a smaller version of it now if that's what you'd prefer, but it's just so easy to control with your foot.  If you can try one out give it a go.  I think the feel is pretty ideal for the intended purpose.
  • JayBJayB Frets: 4
    edited August 2017
    Some great advice here already.
    I have the Thru-Tone PM-1 (when the dollar rate was a little more favourable). It's the Ernie Ball 6166 volume but Justin rips out the circuit and replaces everything with his own switchable buffer and circuitry so you can place it where you wish in the chain.
    Like you I only use pedals in to the front of the amp. Another great alternative may be the Ernie Ball MVP (it's the junior size) but again has quite a transparent buffer.
    Hope it's of some help.
  • Ro_SRo_S Frets: 929
    for swells,  place a volume pedal after gain but before delay/reverb.
    over 20 effects pedals FOR SALE, click here to see my classifieds thread.   My trading feedback
    Effects for Me & my Monkey
    YouTube channel     Facebook         Fretboard's "resident pedal supremo" - mgaw
