Dr.Z thinks it's OK to fit a modern one in a 38W amp, but having seen one of those amps with a blown speaker, I disagree…
It also depends on the amp. Some 30W amps don't put out that much more than 30W even cranked, others do - a lot of it is down to the bias setup, cathode bias produces more compression and less peak power than fixed bias. You can put a pair of Blues in an AC30 and crank it all day long, but try that with a Marshall Bluesbreaker and you'll probably blow them.
Bandcamp
Spotify, Apple et al
Im not sure what the deal is with the reissue vox blue, but I would be pretty sure it can handle a lot more power than an original. So the 15w rating is probably more about appearances and having it look authentic to the original rather than being its actual power rating. Same with the Heritage G12M at 20w.
I'm running a Bluesbreaker style head into two Tayden Ace 25 speakers.
Am I risking damaging them by cranking the amp?
I haven't measured one for a while, but from memory 45-50W. Whether your amp does depends on whether it uses the same spec transformers as Marshall do.
Whether the speakers will take it depends on how conservative Tayden are with their ratings - I have no experience of them. But different companies can be *very* different - Celestion are the most conservative, and their 25W speakers will basically take a cranked 25W amp. Other companies like Fane rate them for more like the actual electrical power input, which can be up to double the amp's clean power, so you would need 50W speaker for the same 25W amp.
My guess is that you're probably safe with that combination, since at worst it's likely to be 50W into 50W… but I can't be sure.
