Hi guys, first time poster. I apologies if I am posting in the wrong place, but I need some help with a Fuzzdog Klone kit build I am doing.
I have put the whole thing together, and it basically works, apart from one small fact which is that the gain control seems to only work as a volume boost, it does not seem to be getting up into actual gain territory. So the sound I am getting from it, is just beginning to get into the slightest bit if grit / distortion, but nothing like a Klon should be able to do.
I have checked the gain pot, given that it is a dual one, and confirmed that both layers are OK. However now I am not sure what I need to test to confirm why the gain is not actually adding gain like it should.
Do you guys have any ideas of what I can do to check or test what is wrong?
Any help or pointers would be greatly appreciated.
http://i.imgur.com/N6oxh0h.jpg
http://i.imgur.com/UgHf3IF.jpg
I think it is the actual clipping that the germanium diodes do that is not working, as overall it is getting plenty loud enough, just no clipping to speak of.
The diodes on the Klon are "hard clippers", meaning that they are tied between the signal and ground. If they're damaged (open circuit) there just won't be any clipping at all. If you have a multimeter, set it to the diode/continuity setting and look for a reading of around 0.3 in both directions.
Other things to look for with the diodes: make sure they aren't cracked. The glass packages on Ge diodes are *very* fragile! Secondly, make sure that you have them the right way round.
Good luck!
I said maybe.....
I said maybe.....
Might be worth getting sockets too so you can audition the replacements without risk of damaging them. If the pedal is just being used at home the sockets are probably good enough to use longer term - if you are gigging you'd be wise to solder - making sure you use a heat sink on each leg o save them from damage.
