Yes, that's basically the difference - the Low produces half the signal level (-6dB gain) and a lower impedance which gives a softer tone - unless you're running a buffered pedal in front, in which case it makes very little difference to the tone. This also can make non-buffered pedals sound much brighter and slightly louder when they're on, relative to the off tone.
The reason you can use them to link amps (or channels on the same amp) is that the gain cut is achieved simply by two resistors, and signal will flow each way through them, so the 'input' can become an 'output'.
You can also plug two guitars in at the same time if you want, in which case both inputs become 'High'.
I also love the tone controls on these amps and never ever use the "cut" switch.
If I were to order a Custom Romany Plus or Pro it would be without the EQ cut and without the 4 way output switch. That would be perfect.
I also tried a hemp speaker recently and absolutely love it (but have realised that I also love the Jensen).
Dennis Cornell urged me not to ditch the Jensen but he did not in any way try to put me off trying a different flavour of (and much louder) speaker.
Surely you can't drive two amps with one guitar plugged only into the high input of one amp?
Like this…
https://i.pinimg.com/736x/66/04/8d/66048daf6d93ffd082f8d4e3620758fa--heart-sounds-musician-photography.jpg
You can even carry on the daisy-chain by linking the second amp to a third one the same way, and so on - although after a couple, it starts to load the guitar down quite heavily and you will lose volume and tone.
