Just moving this query from the main Helix thread to see if anyone has any advice...for 4CM with the helix, where do people set the main volume of the unit (the big knob!)? With my Orange TH30 I'm having to turn it up to at least half way to get any kind of signal through to the power amp. This makes the modelled amps blastingly loud and I have to turn their channel volumes down to about 1 or 2 to compensate (the default is usually 8). Is that normal? I remember a similar thing with the PodHD500X where they said ideally you should run the main unit volume at full for this kind of thing. But then I don't think the modeled amps were so loud.
I'm wondering if turning things down so much will mean I will struggle to get enough signal for sending to the XLR output for going direct to the PA...? Hard to test properly at home but I'm not getting much signal to headphones mapped to the XLR out (I have to turn everything up again to hear it).
Any ideas?
Thanks!
This takes the volume pot out of the equation all together.
You're entirely correct, for this particular way of working, the built in preamps are generally too loud. What you can do is turn down the modelled amp master levels, or add a gain after it and use that to attenuate the signal.
So, if you turn the modelled pre-amps right down to 1 or 2, is there an issue with getting a direct signal for the PA? Do you need to boost that somehow?
I dunno - it may have been a mistake to set up 4CM. I set up a footswitch to toggle between the real and modelled pre-amps, mainly to get the levels sorted, but inevitably I ended up thinking about which I preferred and I always came down on the side of the real amp. It just seemed more open and lively. There's something kind of flat about the modelled amps...not sure how to describe it but when I switch back to the valve amp I just kind of go "ah - there it is". And it was a fairly blind test because I kept forgetting which way round I had set the footswitch but when I checked, it was always the valve amp I preferred.
That's fine I guess..I can always use the helix in 4CM with a real amp but that's kind of overkill for my needs.
This is the thing. I always end up tying myself in knots with these units, then get frustrated and go back to pedals.
