2 speaker cabs 1 head
CastroCastro Frets: 512
People!
If I have two separate 1x12 cabs rated at 8 ohms each and an amp head with one 4ohm one 8ohm and one 16ohm input, is it possible to use both cabs?
Thank you in advance.
  • ICBMICBM Frets: 72490
    Yes, but unless either of the cabs has two jacks, you will need a splitter cable. The two cabs together give a combined load of 4 ohms so you need to connect the pair to that output.
  • CastroCastro Frets: 512
    Thanks ICBM each cab has just 1 jack so a splitter cable it will need to be.
    Much appreciated.
  • 57Deluxe57Deluxe Frets: 7344
    I bought a Palmer Cab Merge box for around £20 to do this
    Image result for palmer cab merger
    <Vintage BOSS Upgrades>
    I'd be more impressed with that if they could spell parallel :).
    Thanks 57Deluxe
  • ecc83ecc83 Frets: 1638
    Hah! The danger with speakers in series externally is the increased risk of an open circuit load. That box plus an amp and two cabs gives you 4 more chances of a blown amp than one speaker (if my pre lunch 'rithmetic is right!)
    Dave.
    I agree. Especially as it looks like the switching is achieved with jack contacts, which are notoriously poor for that - the modern Marshall 4x12"s with the 4/16/mono/stereo input panels being a good example.
    As usual there is a 'good way' and a 'bad way' of wiring the series connection too, which will either halve or double the risk of a failure.
    If it was me I'd just make a box with three jacks in parallel and not worry about the series option - or just a decent splitter cable.
