Technical!! Will the H30 be enough?
timmysofttimmysoft Frets: 1962
thinking of dropping a celestion h30 into an orange Rocker 30 combo, what's the opinion on that? Safe or will the little orange eat it up?
thanks!
  • ICBMICBM Frets: 72447
    Probably safe, but if you don't have the speaker already, get a G12H-75 Creamback instead. Similar-sounding but easily high enough rated.
    The Rocker is cathode-biased so it's quite compressed when it reaches full power. Unless you're absolutely thrashing it with a very bassy sound or heavy fuzz into the clean channel it's probably not going to blow it, but it might sound a bit ragged.
    Wis'd.
    A Creamback or a G12-65 Heritage if you want a more compressed modern sound.
