hi guys,
im looking at getting a small footprint looper. I have previously used an akai headrush but I have no use for the delay feature anymore so looking at a smaller looper to free up space on the board.
anyone had an experience with the ditto or similar and if so can you list any pros and cons for your suggested replacements?
cheers.
heard good things about the Joyo Ironman series mini looper.. can't remember name but yeah..
Ditto a pretty safe bet though.
I suppose there was a bit of tap dancing, but i got pretty used to it. Never used it live though, only in jams and on my own.
There are a few double footswitch loopers on the market (including a version of the ditto) or, for example, the Digitech JamMan SoloXT has an external footswitch jack that allows an additional footswitch (a three button for stop/tap tempo, preset up, preset down but it is possible to DIY a small single button stop switch)
@steamabacus is probably on the right track for what you need, some of the digitech stuff is pretty good. I use the fs1 footswitch he's talking about with some of my digitech stuff, i picked it up for £10.
I haven't used the jamman, but there are plenty about so you could probably get a good used bargain.
Mini loopers in general are 1 button on/off type things. I haven't come across anything different.
I have to say though, the most intuitive looper I have for basic guitar looping is my old Line6 DL4 - separate footswitches for record, loop or loop+continue overdubbing, stop, play once, reverse/half speed ... but it IS massive and fairly simplistic compared to the modern loopers.
It'd be worth checking the manual online to see if it'll do what you want but I think it would.
thanks beexter I will do just that !
thanks @richh but I don't have space for an x 2
Although I found it too limited overall, despite the very cool and useful LED display, so it has now gone. I might get a RC-20 or 30 at some point.
The actual best I've tried so far is the Akai Headrush, but it's too big and doesn't have a battery option, which I prefer for open-mic stuff - less faffing around when you have ten seconds to set up.
