Anyone tried making their own ear moulds?
Emp_FabEmp_Fab Frets: 24312
I've got a pair of Shure 215s and I'm contemplating making my own custom moulds for them as the default rubber hemispheres aren't all that comfy and the cost of having moulds done professionally is just extortion imo.
There seem to be quite a few kits around for you to do your own plugs and I figured it wouldn't be hard to make a pair of custom plugs then drill a small hole in and otherwise Dremel and tweak them so the centre tube of the old rubber hemispheres was now in the middle of the custom plugs.  Click the 215s on and, in theory anyway, one set of custom moulded IEMs for a fraction of the price.
The other advantage is that if they don't fit too well I can file bits down etc or just make myself another set.  I've had moulds done professionally for some  ER20s but didn't like them - they hurt so I got a refund.
Anyone tried making their own?
I could use all sorts if I could be sure it was safe... Silicone, epoxy resin etc.  Make myself a little safety bung on a string to ensure the stuff didn't impact my eardrums etc!
  • SporkySporky Frets: 28227
    Subscribed. What could possibly go wrong?
    11reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • Emp_FabEmp_Fab Frets: 24312
    Well, I have considered the possibility of sitting in A&E with ears full of Araldite.  Or possibly having to live the rest of my life with the Shures permanently stuck in - having to walk around with a small microphone like some mutant reporter.
    An @Emp_Fab thread about DIY and sensitive bodily functions?
    Likewise.
    <space for hire>
    The beauty, and the immense potential in this thread, is that you've considered that possibility but still regard it as worth it 'cos it'll save you money.
    This is gonna be gold :D
    (of course, it's probably going to take a while to get there, but we'll help you along as best we can)
    <space for hire>
  • mike_lmike_l Frets: 5700
    Nothing can possibly go wrong. With the Emp's track record nothing will get done until 2029, at the earliest.
  • have you tried all of the different tips and none of them make a good seal? I got like 10 different ones with mine
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    I had the same set of tips but I've only tried one size so far. It's not that they don't make a good seal but that they hurt after an hour.  I also don't like the pulling of the weight of the wire on the back of my head - it keeps pulling them out slightly.
    I wonder if silicone sealant would work and whether it would harm my ear while curing ?
    edited September 2017
    Or... I could just buy a proper kit...  http://www.earplugstore.com/custom-ear-plugs-oceps-trial-kit.html
    $30 is a shitload cheaper than whatever ACS are charging these days.
  • RolandRoland Frets: 8706
    Have you tried supporting the weight by taping the wire to the back of your neck with surgical tape?
  • octatonicoctatonic Frets: 33798
    They are not comparable though.
    I've done my own moulds, they didn't work properly.
    I now have Read Audio In Ears and ACS & Read earplugs.
    Do it right.
  • Propa bonkers
    Why is it bonkers?  It's only squirting gunk into your ear, waiting, then pulling it out.  Why should I pay someone over a hundred quid to do that if I can do it myself?
  • Danny1969Danny1969 Frets: 10410
    I tried it years ago, got a 2 pack kit of Ebay, mixed it up and put it in my ears until it set then pulled it out. One came out not too bad, the other was crap. Not something I would do again ..... try a bit of tape or some seal on the 215's
    How do you mean?  Tape where?  I'm imagining a two inch wide band of duct tape around my head like Rab C Nesbitt.
  • BigMonkaBigMonka Frets: 1771
    Can you loop the wire over the top of your ear first? That can help stop the strain
  • John_PJohn_P Frets: 2750
    215's are one of the few in ears that I find a comfy fit and a good seal so I didn't replace my lost custom moulds. If they don't work for you then for the cost of the time and limited chance of success from all the reports I've read then it is a reasonable investment doing it properly imo
    Fair enough.  You've all convinced me of the folly of proceeding.  Sorry to disappoint everyone looking for a thread of pure gold!  =)
  • Have you tried the foam insert instead of the rubbery ones? I found they work way better. Don't be afraid to go up a size too.
    I didn't know you could get those for mine.  Thanks mate, I'll check that out.
    @stickyfiddle Are you talking about the squeezy yellow foam ones?
