How to check if they're parallel: connect the amp to one cab, and play through it quietly - or just turn it up a bit further and listen to the background noise, if you can hear it. Plug a spare cable - not connected to anything else - into the other jack. If the sound doesn't cut out then the jacks are in parallel.
Bandcamp
Spotify, Apple et al
Normally the "in" and "out" labelling is unnecessary/incorrect and both jacks are simply connected directly to each other in parallel, with the speaker(s) connected to them as well, so in fact either jack can be the in or out, it makes no difference.
If it was actually a series connection then the in and out does matter, because the output has to break the signal path to insert the second cabinet between the input and the speaker - that's why you can check which it is by putting an unconnected cable into the 'output'.
