Most of the things that you might want to do involve modifying the connections on the neck position pickup. Essentially, you interrupt the grounding connection between the metal pickup cover and the black/ground output conductor wire of the pickup. It becomes necessary to add a separate ground wire between the pickup cover and a pot chassis in the control cavity.
Have had a hunt and found this, I presume it is the one on here?
http://www.seymourduncan.com/blog/seymour-w-duncan/three-cool-alternate-wiring-schemes-for-telecaster
You will need to seperate the earth on the neck pickup cover though
https://sites.google.com/site/phostenixwiringdiagrams/home
As others have said, you will need to disconnect/ run a separate earth to the neck pickup cover. Also, be aware that the standard 4-way switch wiring is prone to noise when the bridge pickup is selected alone. This is because the neck hot is always connected to the output (neck pickup is effectively selected by connecting or lifting earth). When the bridge pickup alone is selected the neck pickup earth is lifted, and since the neck pickup is connected to the output but not earthed it acts as an aerial and introduces noise. There is a minor modification to the standard 4-way wiring which ties both ends of the neck pickup together when the bridge pickup is selected to overcome this problem, and there is a nice diagram for it on the site above.
Also, if you snip the short link between the earth side of the neck pickup and its cover, ensure you cut close to the earth wire end (near the eyelet), such that you leave most of the wire link attached to the pickup cover - this will give you something to solder a new wire onto if you decide to run a separate earth to the cover (some people choose not to connect the neck pickup cover to earth, and feel the neck pickup sounds more open if the cover isn't earthed).
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
