Neutric right angle plug
hotpickupshotpickups Frets: 1822
Can some one help me get this plug apart? I'm trying to get the black plastic cover off and I can't see how it comes off :(
https://imgur.com/a/ZHEAl
Im hoping to learn a new trick (did you see what I did there ;) )
  • ICBMICBM Frets: 72709
    The black plastic piece slides, away from the cable.
    Oh no it doesn't :( I'm thinking I should be pushing down a tab somewhere ?
    My mistake, it's the metal ones which slide. The plastic one lifts at the end nearest the cable.
    At least it does on the one I have here :).
  • FelineGuitarsFelineGuitars Frets: 11643
    Does it have a metal part sticking through the end of the plastic at the top (where we can't see?)
    if so the the part near the threaded bit lifts up , hinging on the aforementioned metal part
  • Paul_CPaul_C Frets: 7855
    lift up the black plastic bit at the end nearest the threads first ?
  • Get a pointy thing, point it in above the cable so it is touching the underside of that black cover, push the cover from inside - jobs a carrot, you are now holding a plug attached to a cable and the black cover is somewhere on the floor
  • RolandRoland Frets: 8779
    The metal piece has two small 0.5mm studs which stick up into indentation in the plastic, preventing it sliding. Lift the cable end of the plastic with a knife blade and it will slide open.
    IMG_0317.JPG 604.6K
  • Your right thanks guys. It lifted off st the thread  end
    Thanks again
  • RockerRocker Frets: 4999
    Get someone else to do it for you.
    Nil Satis Nisi Optimum
    Not half as fun though ;)
