Hi guys,
Avid JMP-1 user, love the system and the flexibility but it doesn't do the edge of break up sound. If you push the cleans too hard it sounds more like digital clipping IMHO.
The only way forward is for me to use pedals but I can't decide which one/s. I've toyed with selling the JMP-1 but just can't bring myself to do it.
I'm half tempted to go for a Wampler Plexi Deluxe but I don't want to throw money at if it's not going to cut it. I'm not a pedal user by traded so their fairly new to me right now, hence the need for advice. I have a Tube Screamer Mini which I use to boost the JMP-1 drive channel over drive but on the cleans it's a bit too nice and it feels like the OD is sitting on top of the clean rather than blending.
Any thoughts or suggestions greatly appreciated.
Thanks in advance
Mike
He got some stunning tones, including some crunchy cleans.
Its possible id say, just requires a bit of work.
I've only ever heard that the cleans on the JMP-1 are a bit lame (which has stopped me buying one in the past) which might explain the struggle you're having.
I have a JMP-1 as @stratman3142 said use OD1 with the gain down for that kind of tone.............. in fact use OD1 for everything, that's what I do
Mines got a NOS Harma valve in it ... I was sceptical about hearing a difference when it was fitted but heard a difference for the better straight away
Thanks for all of the responses and ideas.
This morning I've tried the OD1 channel with the drive right back and to my ears it's a little uninspiring. It sounds like something underperforming as opposed to something being pushed if that makes sense?
I really think I'm only going to get what I want from a pedal, or it's just not going to happen. I had my eye on the Friedman but was little concerned that even on low gain levels it still seems to howl. However, a friend has one so i'm going to borrow it and try first hand. The other pedal I had my eye on was the Wampler Plexi.
Cheers
On the other hand you like a DSL through G12T-75s so we may have slightly different opinions of what excellent is .
The answer to the original question is what Danny said - OD1, gain low.
It's also worth mentioning that there are two valves in it, one is purely for the clean sounds and one purely for the overdrive, so you can experiment with different types for each. I can't remember which way round they are but it's very easy to find out - just pull one valve and see what stops working.
So if the cleans aren't necessarily Fender type cleans how would you describe them? If I remember correctly Def Leppard used them for their recorded clean sounds which I always hated, which might be colouring my memories of how the amp was regarded back in the day.
Obvs no use for 'edge of breakup' stuff, as he was either sparkly clean or uber-drive
The JMP-1 came later...
https://consequenceofsound.net/2017/07/billy-corgan-is-selling-all-his-old-shit/
JMP1 mini anniversary head.
ive used it in front of a Blackstar and it worked very well for what you want, and it has the tubescreamer side so you'd not increase pedal count
(disclaimer I maybe biased)
The Mesa is a very close copy of the circuit, but with all the digital control stuff replaced by simple pots.
I tried the BE-OD and it was crazy gain, way to much for me but I can see why it's popular.
I can't get what I want so am considering a Giggity and Wampler Plexi.
Cheers
Even with the internal gain at it lowest? 'Tis a beast though!
Meant to add, try a Rockett 45 Caliber Overdrive if possible. It has a very usable sweep of the gain control.
