Fender Classic Player - why get a USA standard?
ElwoodElwood Frets: 454
edited December 2017 in Guitar
Is there any reason to get a USA standard over a Classic player.
Without getting hands on I can't see the big improvement - are there any know issues with CP 50's or 60s?
Are the trem systems not as stable etc?
Thanks in advance!
«134
  • Had a classic 50's not player, outstanding guitar.
  • crunchmancrunchman Frets: 11452
    No reason that I can think of.
    I'd get a Classic 50s with a vintage style trem over either of the ones you mentioned.  As @danishbacon mentioned, they are very good guitars.
  • HAL9000HAL9000 Frets: 9684
    I've played a few Classic Players and Classics and they've all been very nice indeed. I think if you want 22 frets and/or the truss rod adjustment at the headstock end then you need the USA Std. Also, I'd guess that the Classics and Classic Players have alloy sustain blocks rather than steel.
  • StefBStefB Frets: 2355
    edited September 2017
    22 frets, truss rod access without having to take the neck off, greater choice of colours and, crucially for some, a 'Made in USA' sticker...
  • LescasterLescaster Frets: 107
    I own a classic player 50s and also a few american standards, the v neck carve on the cp50s feels so much better than the standards. The pickups are great too, very articulate and vintage sounding. The 2 point trem is also just as stable as the standards.
    Definitely try them side by side but they are fantastic guitars.
    Edit: just remembered that the frets are quite thin and tall though, so if you prefer a larger fret this may be an issue.
  • WhitecatWhitecat Frets: 5426
    The resale value is a little better on US instruments, as is the speed of sale in most cases. Not a tonne, but a little, IME. I don't personally mind that so much either way but some do.
  • johnhejohnhe Frets: 191
    I much prefer the more vintage-like hardware on the Classic Players than the modern look of the standards. But then again, I sold my AM Std and bought a Classic Player 60's strat, so I'm clearly biased.
  • ElwoodElwood Frets: 454
    Cheers guys, the truss rod access at the heal is always a PITA but atleast it doesn't need to be done regularly.
    Will keep an eye out for a 2 tone. Thanks for the help!
    If you sent me out now to buy a new Fender for £900-1500 new I'd probably buy an American Special Tele or a Am Elite Strat
  • ricorico Frets: 1220
    jeztone2 said:
    If you sent me out now to buy a new Fender for £900-1500 new I'd probably buy an American Special Tele and a Am Elite Strat
    That's not possible.
  • The best strat i have played is a strat plus. Hands down
  • NeilNeil Frets: 3625
    Only the tuners surely?
    They both have the modern style two point trem which TBH I find a bit incongruous on a vintage style guitar.
    Does @johnhe mean the Classic Series rather than Classic Player?
    Dunno, he said Classic Player.
  • guitars4youguitars4you Frets: 14290
    edited September 2017 tFB Trader
    Same shape but in many ways a different spec'd guitar regarding so many issues - neck shape, fret size and fingerboard radius so how it feels and plays will always be a matter of opinion - Different pick-ups and I suppose again a matter of opinion
    Regarding the trem - bot J Beck and H Marvin use a trem on most notes they play - yet both favour a different system and both can use such trems without tuning issues - Buying of the shelve then there might be a set-up issue on the trem that might require a tech to fine tune the set-up to suit you and operate without tuning issues - For serious dive bombing or heavy use then neither systems are ideal, but for 'regular' use that is more f a shimmer to 1/2 or full tone, then both systems should work fine - The system do feel a touch different so again a matter of taste
    The USA version will obviously cost a bit more so on paper maybe you'd expect a superior guitar, yet the Mex Classics are not toys, so best bet is to try both and see which ticks the right buttons
    i know my bloody spell check changed or to and!
    I was more thinking of £400ish for a CP60 vs 600ish for an Am Standard!
    1500 I would go for a PRS!
    if you are looking at a Used AM Std, then look for a latter version with rolled fingerboard edges and Custom Shop p/ups - IMO a better guitar than earlier models - even if a touch more than £600
    Cheers G4you. It's some way down the line as i've not been able to make my mind up. Would proberbly end up with a bridge humbucker at some point, or more, so the AM standard might be the way to go. I think CP's are only routed for single coils - if it's good enough for Dave Murray though, it's definitely good enough for me!
    equally a used CP for around £400 ish - and you prefer the feel etc, then you can always spend £100/200 on a set of new/used boutique p/ups as required
