this is a 50's based in 'baby pink' built in 2008 according to his certificate
Let me know if you need any info on this guitar.
Thanks!
www.mbguitars.co.uk
INSTAGRAM
Two questions - did you build from raw wood upwards ? - or by pre-cut body/necks etc and assemble as such, if the latter then can you remember from who do you by body/necks - also the bridge /trem assembly with pat pend saddles - is this from Fatboy Guitar parts ?
Anyway, this was the very first one I built, for a chap that saw my passion for vintage strats and had seen my own projects and finishes. After telling him I didn't build guitars to order and only built for myself, he came back and begged me to make one for him.. so I did!!
This one was the very first build, and the customer wanted to keep the cost down so opted for a WD Hosco Body and neck, out of their Japanese factory, very high quality.
I believe the tremolo system was made by Gotoh and the saddles were from Crazy Parts in Germany, and plastics from Fatboy Guitars.
Every guitar I made after this were hand made from a lump of wood that I selected and routed out on CNC from original templates and hand finished by myself, same for the necks. That meant I was able to offer period correct contouring, neck and body shapes, dot spacing, fingerboard spec etc. Even the pick guards were cut on CNC from original templates and sent to Mark foley for ageing.
I only ever made around 10 instruments over the 2.5 years I had Operationstrat, but unfortunately a career change and being on tour a lot meant I was no longer able to keep building to realistic time scales so decided to stop altogether.
I am looking however to get back to it at some point so watch this space! Am very happy to hear my instruments are still out there and being used.
Thanks
Mike
www.mbguitars.co.uk
INSTAGRAM
