Removing a dent from a steel guitar?
equalsqlequalsql Frets: 6104
I've got a rather lovely Gretch Honeydipper steel (brass) guitar finished in a light translucent green. I'm not sure if the finish is somehow plated on.
Unfortunately I managed to ding the top side of it and have thought about removing the cone assembly and seeing if I can tap it out using a small hammer whilst supporting the opposite side on a leather pad.
I think this should work as the finish didn't crack when the ding occurred.
Any advice folks?
  • ToneControlToneControl Frets: 11894
    edited September 2017
  • equalsqlequalsql Frets: 6104
    Looks like my level of metalwork :)
  • ICBMICBM Frets: 72323
    Is it the 'classic National dent'?
    https://upload.wikimedia.org/wikipedia/en/6/67/DS_Brothers_in_Arms.jpg
    I would probably leave it. It's very hard to get a dent out of metal without a fair amount of work - the metal has actually stretched, so getting it to go back to its original shape is difficult - and you'll most likely damage the finish.
  • 57Deluxe57Deluxe Frets: 7339
    <Vintage BOSS Upgrades>
  • GassageGassage Frets: 30912
    A mate of mine had a big ding in a Trussart. He asked Dentmasters to sort it (car body repairs) and they did a top job.
  • CorvusCorvus Frets: 2925
    That might be a good idea or an old-school panelbeater. You want a wooden mallet and a metal dolly (a shaped heavy steel block). Using a metal hammer will just stretch/thin it. If you don't balance the hammer/doly strikes the whole panel could move. It's easy to make a mess. Depending on the dink it might need annealing or could crack as it's being re-shaped, and plating/finish will prob suffer. Either chalk it up as character or find a panelbeater type person if you're really bothered by it.
    Image result for father ted dent in car
  • You can remove a dent from a steel guitar... but you can never remove the djent from a metal guitar! \m/
  • ESBlondeESBlonde Frets: 3588
    I used to work for an engineering company who had some very skilled staff, one being an aerospace pipe/flue specialist. One day some tube had been bent at right angles but the bend was in the wrong place, bending stretches the metal and alters the thickness of the walls. The tube was special and supplied by the customer so making a new one wasn't an option. Anyway this guy beat the 4" tube back straight with the correct wall thickness using nothing but a polished bar and a simple ball mandrel as an anvil. Once corrected the tube could be reinserted on the bending machine and made correctly. That sort of skill is dying out in engineering sadly but was a wonder to watch.
    We definitely need a 'groan' tag for sush bad puns :mrgreen:
    Utter genius. Cap doffed.
