Hi all
I have a disater Area DPC5 Gen3
http://www.disasterareaamps.com/shop/dpc5-gen3 It has a nice CTRL for switching amps in a split TRS to TS/RS
I want to use this for controlling/switching a looper in if/else config
So i have 2 compressors, one a light blend the other a heavy andy summers squissh
never on at the same time
so i want to assign a single loop for both pedals and use a single TS switch to choose one or the other...
so in the DPC5 loop 1 i would have in/out going to a box that is controlled by the Tip/sleeve
the box also has send retruns 1 and 2 for each of the compressors
I can power with a 9v spare i have
Then same again but switched by Ring/sleeve ? with 2 alternate drives
This would give me 7 pedal options on the floor instead of the five
Is this possible?
No idea about how i go about doing this...??
Thanks
