In theory there could be a difference in neck stiffness, which I do believe to be a factor in the instrument's tone, but I've not played enough similar instruments in 22 and 24 fret configurations to decide if the extra length is a significant factor to rigidity. I guess that's a question for one of the builders here
Traditionally, the Gibson SG had a twenty two fret neck but the joint caused the neck position pickup to be placed closer to the bridge than on, say, a Les Paul.
Gibson now offers twenty four fret SG guitars. The neck position pickup has not been relocated. All the theory in the world would suggest that these two variants will sound the same ...
... until you hand them to a different player.
Contruction wise the 24 should be much brighter than the 22.
But the opposite is true.
Or have I just walked into some sort of trap?
24 is bolt on maple neck alder body.
The 24 is bolt on alder body maple neck
the 22 glued in mahogany body and neck.
The 22 is dramatically brighter acoustically than the 24.......
(they have different pickups the 22 having softer vintage style and the 24 having bright hot ones, they sound similar plugged in)
It's the best I've got to work with, my band have stopped returning my texts and my wife 'has a headache'
again.
For the same note (i.e. Same string and fret position) the neck pickup will hear a different harmonic mix. Whether the note has more treble, mid, or bass content will depend on which note is being played. Averaged over all the notes I would expect the neck pickup on a 24 fret guitar to be slightly less bassy than a 22 fret guitar, because it's nearer the bridge; but that's statistical averaging, and not necessarily evident in any particular song.
Neck length and stiffness are more interesting. It has been said that many early 24 fret PRSs had dead spots. I have read that PRS addressed this by lengthening the neck tenon.
almost all other guitars require you to move pickup or neck join to accommodate all 24. It's the factors you have to change that can introduce the variation in tone.
Neck stiffness is a big one for me, but pickup position is undeniably more important in the overall sound
Instagram
It will be because of the maple cap on the body, compared to the all-alder body. PRS Custom bodies are actually 50/50 maple and mahogany if you look at them in cross-section, even though it doesn't look like that at the edges.
In this case it's obviously having a bigger effect than the neck difference.
I definitely notice a fuller neck pickup tone from the 22, always have done.
but it's perhaps the overall tone that I'm getting at.
my bad...... I have full blown man flu.
Apologies.
