http://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=05257370 "Modeling the Temperature Dependence of Hysteresis
Based on Jiles–Atherton Theory" A. Raghunathan et al.
Perhaps more useful might be this article on selecting core materials http://www.mag-inc.com/File Library/Product Literature/Strip Wound Core Literature/twc-s2.pdf which shows properties for some different core materials and also talks about the (relatively obvious need) to take into account expected operating temperature. So transformer temperature could affect efficiency depending what material is used, but it'll take a while for a core to warm up, other components probably warm much faster. On ecc83's point about low thermal mass of speaker coils, it's true they'll quickly get back to the amp ambient, but if the whole amp is warming slowly then the temperature they're at is going to be changing at that pace. Thinking about it the resistance of a big coil of wire might be one of the more temperature dependent things, something you should see more in combos than separate head+cab then?
Bandcamp
Spotify, Apple et al
So the speakers' impedance will be different in a cold room - more current passing, so more efficient and louder (?), as will the resistances in the amp itself.
I'm not sure if the movement of the speaker coil and/or use over time will alter its temperature without more, though.
