I have one Gibson '57 Classic stashed away somewhere. I would need to check its condition before offering it for sale.
Do you have D.C. resistance meter readings for the stock Korean PRS pickups?
US Tremonti pickups are (DC RES) Treble 15.42k and Bass 7.39k
Apparent Korean pickups are Treble about 10 and bass about 9k, but I didn't take measures.
C.
Does your SE Tremonti have a fixed "wrap over" bridge/tailpiece or a six screw fulcrum vibrato? One of the reasons for choosing a high resistance and ceramic magnet humbucker would be to compensate for the body mass lost to the vibrato cavity.
I do plan to replace the bridge pickup, it's just I've never got around to it, as I'd quite like to add push/push pots with coil splitting at the same time, just so I can experiment more.
What I try to achieve here is a bit fattier sound, rich in mids & low end not too much high output/gain etc,
I mainly play blues, rock, so want to get warm, rich sound.
Chris
PS:
@dcg - are these Bare Knuckle Mule - how do they sound ?
...or perhaps Tonerider Rocksong set if less to spend. Haven't tried either of these, I should add... I do have an Oil City order in at the moment, and the proprietor is a nice chap who knows his stuff.
Yeh, don't want to spend fortune...
RE: Bare Knuckle Mule - wow, would be a good fit but the price is rather high!!
Oil City PAT 63's sound like they might be in your ball park too:
http://www.oilcitypickups.co.uk/hbclassic.html
https://i.imgur.com/Lgh6WjK.jpg?2
https://www.mojopickups.co.uk/product-category/pickups/paf/
https://www.mojopickups.co.uk/product-category/pickups/humbuckers/
Feedback
C.
Bridge: 9,42
Neck: 8,66
At the low-end are a range of made-in-China options. I've found Iron Gear to be consistently good for the money.
At the top-end you have BKPs, but as you've already said, they're pricey.
In the middle you have the independents such as Mojo (linked above), Bulldog and Oil City. Each of those is run by someone who understands pickups, and makes excellent quality units. If you can articulate what you want, they'll either tell you which of their products meets your spec, or tell you that none of theirs does, so they'll either wind you something unique or they'll recommend someone else.
You wouldn't go wrong with any of them. Check their websites, think about what you want, and then check back here because many of us have got experience of most of them.
