So i recently got an Iceman and it has an extreme case of neck dive!
I'm not one for caring too much about this stuff and usually make do with unbalanced guitars...but this is an extreme case. I find myself having to support the neck as i play, which can get very tiring.
I've done some research online and its a common problem on this particular model (IC400) and the consensus is that the button has to move closer to the neck joint.
Now, i dont have any tools, besides a few screwdrivers at home, and i've never modded a guitar in the past besides sanding down the back of a few necks. What i wanted to know is, what is the work involved in moving the strap button, what are the dangers of drilling holes in a guitar especially so close to the neck join and what could potentially go wrong?..also any other suggestions to remedy the situation.
for reference, here's a shot of where the button is
(BTW...this is not my picture)
The thing i was worried about was not going through the neck to the fretboard, but more about messing with the neck joint, but that doesn't seem to be an issue.
the last thing on my mind was how i fill the current hole? is it just a matter of some plain old putty?
Put a short screw in it. It will then look like it's supposed to be there
