Thanks!
It's paint - a coat of primer and then black until it was flat, then mask it and a layer of white, then mask it again and a layer of red. Sort the binding and then a few coats of lacquer.
I actually redid it as I wasn't happy with the first pattern - this one isn't quite how I had planned it but I just wanted it done so I could play it.
Thanks
I masked it while I painted the back and sides, when I was happy with with the back I scraped it and then did the same while I faffed about getting the top right. A bit of a pain tbh as the masking isn't completely straight up like my les pauls - it edges in slighty - only a mm or so but enough to make it hard to mask or scrape neatly.
